FSI Transient Load Mapping (ACT)
Old   November 1, 2016, 08:48
Default FSI Transient Load Mapping (ACT)
Attique Javaid
attiquejavaid08 is on a distinguished road
FSI Transient Load Mapping ACT extension: imports transient pressure and temperature profiles in ANSYS Mechanical for 1-way FSI. (Coupling Transient CFD with Transient Mechanical). One doesn't need to go for System Coupling module.
But imported pressure is gauge pressure computed in FLUENT. Talking about System Coupling, in documentation it is advised to set such value of reference pressure in FLUENT that exported pressure results in actual system pressure while coupling. (Submerged pipe example is given in documentation)
In my case, using ACT extension, i've set desired reference pressure and it was expected to behave same but it's still exporting gauge pressure instead of actual system pressure (gauge + reference). May be, i didn't expect it right or my methodology is wrong. Can someone guide me please.
attiquejavaid08 is offline   Reply With Quote
Old   November 10, 2016, 03:28
Attique Javaid
To those, who'll be looking for it's solution.
If Absolute Pressure is already in exported variables list, just change the 'Pressure' to 'Absolute Pressure' in CFD Post Macro you got with this ACT Extension.
In my case, it was not present. I just defined a variable representing absolute pressure (gauge + reference) and put that in cfd-post macro.
regards,
Attique Javaid
Structural force in FSI mapping Fluent 12.0 benjamon FLUENT 1 October 24, 2011 11:32
FSI - verification force mapping with mfx Vinzent CFX 15 September 18, 2011 19:00
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. CFX 2 September 15, 2011 16:30
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. FLUENT 0 September 14, 2011 16:40
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
