October 31, 2016, 22:28 |
License file error?
T.SUGAWA
Hello.
When I install the ANSYS17.2 (academic) to a new computer, serious comes out the following error messages, etc. Workbench problem has occurred. From here, you know that you are not able to connect with the license server (stella). However, two of the port number and the host name is not wrong, the server is also operating normally. Perhaps, I have and I think because it is not able to, such as authentication of the problem or license of the connection settings on the PC ···. Because the license manager was written in the guide that there is no need to the client PC, it does not install. Could you help. It offers if there are any information necessary to the other. Overview The following OS windows 7 Pro CPU Xeon Used as a client PC |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
