ICEM Pre-Mesh failed
Old   September 21, 2016, 03:03
Default ICEM Pre-Mesh failed
Kim
k.ing is on a distinguished road
Hello CFD-Online Community,
this is my first thread and I hope you could help me.
I actually have two problems in ICEM. I tried everything (I guess).
I created a 2-D model with blocks in CATIA V5. After that I imported it in ICEM 14.0. So far everything was fine. The program was also able to create automatically all blocks. After that I started to set the mesh parameters. And there was the first problem.
Note: I want to create a structured mesh to properly investigate the turbulent kinetic energy in fluent.
  1. In the picture "unconnected_nodes" to see to it that the nodes aren't connected. In the left block I have a distribution of 100 nodes and in the 3 left blocks there are 100 nodes overall too. I know that there is not the right distribution in aspect to the ratio, but I would like to know a solution where ICEM could discern that and create a mesh with connected nodes. I tried both ways. Set the parameters for the big block first and the 3 blocks afterwards. And the other way around. I can't work with linked bunching because there are different distribution in nodes. If there is no solution I would try to solve that mesh in fluent. Fluent should be able to connect the hanging nodes with adjacent nodes. But that is not what I strive for. So if someone knows a way to create a coherent mesh that would be great.
  2. My second problem is something I never had before. In the picture "thicknessfail_ICEM" is the problem demonstrated. ICEM is not able to create the curvature externally. There is no problem to create the mesh inwardly. I tried every associate possibility (vertice-point, edge-curve, surface-face and everything together or just two of them...) but nothing works.
It would be great if you help me.
Thanks in advance!!!
Kim
k.ing is offline   Reply With Quote
blocking strategy, icem 14.0, mesh 2d
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
[Commercial meshers] Failed checkMesh - ICEM converted mesh elebelly OpenFOAM Meshing & Mesh Conversion 2 December 11, 2013 03:53
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
