ANSYS Icepak.
Old   September 20, 2016, 04:34
Post ANSYS Icepak.
Bhuvan
bkhoshoo is on a distinguished road
Hi. I am trying to do a steady state thermal simulation with a 2 panel configuration (both are GIS). Tank of one GIS is filled with air and the other is filled with SF6. I understand that their is an option to select the default fluid (i set it as Air) which is there in the complete domain.
Now for defining SF6, i am confused as in how to proceed?
Should i make a block of the size of the GIS tank and provide it Fluid properties? I am not sure whether to use Boolean operation in this fluid block with the parts present inside the tank (remove the portions of Fluid block interfering with parts inside the tank) or not?
I tried both the options but i am still getting error saying problems in mesh. I think the mesh is just fine.
Could you please help me out here?
Thank you.
bkhoshoo is offline   Reply With Quote
Old   September 21, 2016, 08:26
Antanas is on a distinguished road
Thank you.
To modify cabinet shape you may use blocks of type "Hollow" (there will be no mesh inside) and "Fluid" (for ex. to make fluid passages through solids or hollow blocks). You don't have to use boolean operation as there's no such in Icepak. But you should set correct meshing priorities for intersected objects. Objects with higher priority will determine properties (and mesh) in correspondent region.
Antanas is offline   Reply With Quote
Void Fill in ANSYS Icepak nazemi ANSYS 4 January 31, 2019 07:38
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
Ansys Icepak jitender ANSYS 1 January 22, 2010 04:41
