Two way FSI error msg
Old   September 19, 2016, 10:06
Default Two way FSI error msg
Haoxin Xu
haoxin is on a distinguished road
I am running a two way FSI with Transient Thermal and Fluent for coupled thermal analysis.
The geometry is simple: a thick SiC wall with one side attached to a pipe which runs superheated steam. The other side of the wall receives high temp radiation.
I've set up both TT and Fluent. Everytime I run the system coupling solution, it just abort automatically with the error messages down:
System coupling run completed with errors. System Coupling Service reported: System coupling run aborted by user or due to fatal error: A solver failure occurred during the run in the Transient Thermal system Please do not save the project if you would like to recover to the last saved state.
Anyone has any idea what caused the error?
***** ANSYS COMMAND LINE ARGUMENTS *****
BATCH MODE REQUESTED (-b) = NOLIST
INPUT FILE COPY MODE (-c) = COPY
2 PARALLEL CPUS REQUESTED
START-UP FILE MODE = NOREAD
STOP FILE MODE = NOREAD
CONNECTION TO COUPLING SERVER REQUESTED
SYSTEM NAME = Solution
HOST NAME = 0.0.0.0
SERVER PORT REQUESTED = 59011
20100520 VERSION=WINDOWS x64 RELEASE= 15.0 UP20131014
CURRENT JOBNAME=file 20:53:14 SEP 19, 2016 CP= 0.842
*** FATAL *** CP = 0.842 TIME= 20:53:15
MAPDL is unable to connect to the system coupling service on 0.0.0.0
through port 59011. Please ensure that the service is running.
*** FATAL ***
Random read error on unit= 16 possible corrupt or missing file.
I/O status error= 0
haoxin is offline   Reply With Quote
fsi 2-way coupling
FSI: How to transfer static pressure from fluent to ANSYS momo_sjx FLUENT 0 October 9, 2012 14:37
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 05:14
initial file for fsi modeling? mortazavi CFX 0 July 21, 2009 03:06
fsi sun Siemens 8 January 20, 2009 00:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
