September 15, 2016, 13:47 |
Trouble with Add-ins
Jacob
Rep Power: 10 |
I'm trying to import a .dwg file from AutoCAD into workbench. When right-click "geometry" and select "import geometry" it says "the selected file is of an unsupported or unconfigured geometry type". I opened the CAD Configuration (as administrator) and selected AutoCAD and Solidworks on the "CAD Selection" tab. I then clicked "Next" and clicked "Configure Selected CAD Items" on the "CAD Configuration Tab".
This is what it said: Prerequisites ..... Configure Success SW Workbench PlugIn ..... Not Configured ACAD Workbench Reader ..... Not Configured The Configuration Log says this: <<SolidWorks PlugIn>> Invalid SolidWorks Dll File Path in createAnsRegistryXML2 C:\Program Files\ANSYS Inc\v171\aisol\CADIntegration\SolidWorks\winx64\WB 171PlugInSWCOM.dll __________________________________________________ ____________________ <<AutoCAD Workbench Reader>> Invalid AutoCAD Dll File Path in createAnsRegistryXML2 C:\Program Files\ANSYS Inc\v171\commonfiles\CAD\Spatial\iop\NT_VC11_64_DL L\code\bin\DSSpatialImportCOM.dll Skipping Ansys Registration: C:\Program Files\ANSYS Inc\v171\commonfiles\CAD\Spatial\iop\NT_VC11_64_DL L\code\bin\DSSpatialImportCOM.dll does not exist Package may not have been selected for install. ACAD Workbench Reader ..... Not Configured Can someone please help me find out how to get these installed? Thanks. |
September 19, 2016, 05:48 |
Onur Özcan
Rep Power: 12 |
As you import .dwg, .dwg must be open. it is one of import method,
So, method I can give you .. 1) Double click ''Geometry'' 2) File>import 3) Update it as you do all items above, rule: .dwg or something extension you use must be opened |
[PyFoam] and paraview | eelcovv | OpenFOAM Community Contributions | 28 | May 30, 2016 10:23 |
How to add Exner equation in settlingFoam | jimbean | OpenFOAM Running, Solving & CFD | 1 | October 6, 2013 10:59 |
.setSet problems | Grimoli | OpenFOAM | 9 | July 31, 2013 14:24 |
How to add source for UDS on a virtual surface? | SimulatingFlow | Fluent UDF and Scheme Programming | 1 | May 22, 2013 09:11 |
How to add fire source in STAR-CD?? | raymond | Siemens | 2 | February 22, 2002 14:49 |
