September 9, 2016, 07:25 |
Ansys Licence Serve on Ubuntu 16.04 LTS
David
Rep Power: 13 |
Hi guys,
I am trying to install the Ansys license server on ubuntu 16.04 LTS x64. I am not able to finish correctly the installation procedure: Code:
2016/09/09 11:59:08 *** ATTEMPTING TO START THE TOMCAT SERVER, IF IT'S NOT RUNNING... 2016/09/09 11:59:08 ...Using JRE from the following location: /usr/ansys_inc/shared_files/licensing/tools/java/linx64 2016/09/09 12:01:09 ...FATAL ERROR: The Tomcat server did not start correctly. Please check the Tomcat log files. 2016/09/09 12:01:09 The licensing configuration cannot continue until this issue is resolved. Exiting. Code:
set 09, 2016 11:14:13 AM org.apache.catalina.core.AprLifecycleListener init INFORMAZIONI: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/ansys_inc/shared_files/licensing/tools/bin/../lib/linx64:/tmp/ans_install_tmp1546::/ansys_inc/v172/aisol/lib/linx64:/ansys_inc/v172/aisol/dll/linx64:/usr/lib64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib set 09, 2016 11:14:14 AM org.apache.coyote.AbstractProtocol init INFORMAZIONI: Initializing ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:14:14 AM org.apache.catalina.startup.Catalina load INFORMAZIONI: Initialization processed in 1637 ms set 09, 2016 11:14:14 AM org.apache.catalina.core.StandardService startInternal INFORMAZIONI: Starting service Catalina set 09, 2016 11:14:14 AM org.apache.catalina.core.StandardEngine startInternal INFORMAZIONI: Starting Servlet Engine: Apache Tomcat/7.0.55 set 09, 2016 11:14:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/work set 09, 2016 11:14:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/work has finished in 186 ms set 09, 2016 11:14:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/lib set 09, 2016 11:14:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/lib has finished in 161 ms set 09, 2016 11:14:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/bin set 09, 2016 11:14:16 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/bin has finished in 152 ms set 09, 2016 11:14:16 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/temp set 09, 2016 11:14:16 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/temp has finished in 143 ms set 09, 2016 11:14:16 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/conf set 09, 2016 11:14:16 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/conf has finished in 132 ms set 09, 2016 11:14:16 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/logs set 09, 2016 11:14:16 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/logs has finished in 158 ms set 09, 2016 11:14:16 AM org.apache.coyote.AbstractProtocol start INFORMAZIONI: Starting ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:14:16 AM org.apache.catalina.startup.Catalina start INFORMAZIONI: Server startup in 2018 ms set 09, 2016 11:35:50 AM org.apache.coyote.AbstractProtocol pause INFORMAZIONI: Pausing ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:35:53 AM org.apache.catalina.core.StandardService stopInternal INFORMAZIONI: Stopping service Catalina set 09, 2016 11:35:54 AM org.apache.coyote.AbstractProtocol stop INFORMAZIONI: Stopping ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:35:56 AM org.apache.coyote.AbstractProtocol destroy INFORMAZIONI: Destroying ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:39:12 AM org.apache.catalina.core.AprLifecycleListener init INFORMAZIONI: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/ansys_inc/shared_files/licensing/tools/bin/../lib/linx64:/tmp/ans_install_tmp2288::/ansys_inc/v172/aisol/lib/linx64:/ansys_inc/v172/aisol/dll/linx64:/usr/lib64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib set 09, 2016 11:39:13 AM org.apache.coyote.AbstractProtocol init INFORMAZIONI: Initializing ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:39:13 AM org.apache.catalina.startup.Catalina load INFORMAZIONI: Initialization processed in 1663 ms set 09, 2016 11:39:13 AM org.apache.catalina.core.StandardService startInternal INFORMAZIONI: Starting service Catalina set 09, 2016 11:39:13 AM org.apache.catalina.core.StandardEngine startInternal INFORMAZIONI: Starting Servlet Engine: Apache Tomcat/7.0.55 set 09, 2016 11:39:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/work set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/work has finished in 210 ms set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/lib set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/lib has finished in 160 ms set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/bin set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/bin has finished in 139 ms set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/temp set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/temp has finished in 138 ms set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/conf set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/conf has finished in 123 ms set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/logs set 09, 2016 11:39:15 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/logs has finished in 153 ms set 09, 2016 11:39:15 AM org.apache.coyote.AbstractProtocol start INFORMAZIONI: Starting ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:39:15 AM org.apache.catalina.startup.Catalina start INFORMAZIONI: Server startup in 2076 ms set 09, 2016 11:58:07 AM org.apache.catalina.core.StandardServer await INFORMAZIONI: A valid shutdown command was received via the shutdown port. Stopping the Server instance. set 09, 2016 11:58:07 AM org.apache.coyote.AbstractProtocol pause INFORMAZIONI: Pausing ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:58:07 AM org.apache.catalina.core.StandardService stopInternal INFORMAZIONI: Stopping service Catalina set 09, 2016 11:58:08 AM org.apache.coyote.AbstractProtocol stop INFORMAZIONI: Stopping ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:58:08 AM org.apache.coyote.AbstractProtocol destroy INFORMAZIONI: Destroying ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:59:11 AM org.apache.catalina.core.AprLifecycleListener init INFORMAZIONI: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /usr/ansys_inc/shared_files/licensing/tools/bin/../lib/linx64:/tmp/ans_install_tmp7320::/ansys_inc/v172/aisol/lib/linx64:/ansys_inc/v172/aisol/dll/linx64:/usr/lib64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib set 09, 2016 11:59:12 AM org.apache.coyote.AbstractProtocol init INFORMAZIONI: Initializing ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:59:12 AM org.apache.catalina.startup.Catalina load INFORMAZIONI: Initialization processed in 1591 ms set 09, 2016 11:59:12 AM org.apache.catalina.core.StandardService startInternal INFORMAZIONI: Starting service Catalina set 09, 2016 11:59:12 AM org.apache.catalina.core.StandardEngine startInternal INFORMAZIONI: Starting Servlet Engine: Apache Tomcat/7.0.55 set 09, 2016 11:59:13 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/work set 09, 2016 11:59:13 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/work has finished in 179 ms set 09, 2016 11:59:13 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/lib set 09, 2016 11:59:13 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/lib has finished in 153 ms set 09, 2016 11:59:13 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/bin set 09, 2016 11:59:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/bin has finished in 133 ms set 09, 2016 11:59:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/temp set 09, 2016 11:59:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/temp has finished in 133 ms set 09, 2016 11:59:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/conf set 09, 2016 11:59:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/conf has finished in 161 ms set 09, 2016 11:59:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deploying web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/logs set 09, 2016 11:59:14 AM org.apache.catalina.startup.HostConfig deployDirectory INFORMAZIONI: Deployment of web application directory /usr/ansys_inc/shared_files/licensing/tools/tomcat/logs has finished in 115 ms set 09, 2016 11:59:14 AM org.apache.coyote.AbstractProtocol start INFORMAZIONI: Starting ProtocolHandler ["http-bio-127.0.0.1-1084"] set 09, 2016 11:59:14 AM org.apache.catalina.startup.Catalina start INFORMAZIONI: Server startup in 2107 ms Thank you very much!!! |
January 11, 2017, 18:02 |
K S
did you find a solution for this problem. I am having the exact same thing going on now. I would be happy to hear something! Thanks!!! |
January 20, 2017, 12:52 |
Solution
K S
The solution can be found in the ansys knowledge resources.
Hope it helps someone with the same problem: https://support.ansys.com/AnsysCusto...%20SYS/2042700 The Tomcat process is needed for the new (from R16.0 onward) License Management Center. Sometimes on Linux systems, the License Manager installation will fail at the configuration stage with an error message that the Tomcat service could not be run. This is caused by the failure of the installation process (permissions, files in use, ...) to move all the binaries from the folder /home/ansys_inc/shared_files/licensing/linx64/update up one level to /home/ansys_inc/shared_files/licensing/linx64. Resolution: This can be resolved by finishing the installation manually as follows: 1) execute the following command to find any "ansys" process already running: ps -ef | grep ansys 2) stop them or kill them using their PID: kill -9 PID 3) go to "/home/ansys_inc/shared_files/licensing/linx64/update" and move all binaries in this folder to one level up with the command : mv * .. 4) if you want, in "/home/ansys_inc/shared_files/licensing" folder, create a backup folder (for example "backup-date") in order to save the log files in this backup folder : mv license.log* backup-date mv ansysli_server.log* backup-date 5) check that the license file is correct using: more /home/ansys_inc/shared_files/licensing/license_files/ansyslmd.lic 6) check that the initialization file is correct using: more /home/ansys_inc/shared_files/licensing/ansyslmd.ini 7) start the ANSYS License Manager using: ./start_ansysli The License Manager should start normally. |
ansys 17, license, linux |
[OpenFOAM.com] Binary install doesn't start on Ubuntu 16.04 LTS | camino123 | OpenFOAM Installation | 8 | September 7, 2017 05:44 |
[OpenFOAM.org] OpenFOAM 2.40 installation on Ubuntu 12.04 LTS | eddykendo | OpenFOAM Installation | 1 | July 18, 2015 18:38 |
Ansys fluent 13.0 on ubuntu 10.04 | mundhwam | FLUENT | 2 | September 1, 2011 11:14 |
Ansys 12.0 on Ubuntu 10.10 64bit | Krischan | ANSYS | 1 | April 26, 2011 05:44 |
ANSYS FLUENT 12.1.4 on ubuntu 10.04 | mundhwam | FLUENT | 0 | June 28, 2010 16:34 |
