August 31, 2016, 07:38 |
Impact of closing door (sliding) on a person
Rep Power: 10 |
Hi all,
I need some tech help. I need to know if we can simulate the below scenario: A sliding door is made up of steel. It has a rubber beading (cross section known) at the edge. The door slides to closed position with a certain speed. Can I model and analyze the force which will act on a person trapped between the doors. Thx AD |
September 5, 2016, 00:47 |
Rep Power: 14 |
yes, you can place a body between door opening and closing position and measure it on the surface of body
September 5, 2016, 01:23 |
#3 | |
Rep Power: 10 |
Thx for the reply. I was planning to undertake the analysis in ANSYS. So how do I go about it. I thought of simplifying the problem into only modeling the rubber bead. One end the force of the closing door will act and the other end the body will act as the "stopper". Do you have any suggestions as to whether this approach is correct and also what parameters I should assume for simulating the rubber and the human body properties? Thx in advance. Anthony |
ansys |
Particle Impact Angle for Expressions in CFX | mabna | CFX | 0 | June 17, 2015 19:28 |
impact force (shear stress) by waterjet impingement | herozhu | Main CFD Forum | 0 | May 7, 2014 20:39 |
Bai model droplet-wall impact / elastic rebound | crevoise | STAR-CD | 3 | November 15, 2012 14:06 |
Impact velocity and angle from DPM model in Fluent | eng775 | FLUENT | 0 | September 4, 2009 14:34 |
Plotting particle wall impact angle (Lagrangian pt | Bart Prast | CFX | 0 | January 26, 2009 04:23 |
