August 23, 2016, 11:10 |
Faceted Geometry Import Smoothing
Jeff
Rep Power: 10 |
So I'm trying to import a geometry into Ansys Mesher that has a shallow curved face. The problem is that the minimum angle between segments means that the boundary is not smooth once imported, it appears faceted. Is there any way to reduce the minimum angle between geometry facets and improve the curve quality? This isn't a mesh resolution issue.
I'm importing using Solidworks & Step files. Each gives the same issue. |
meshing, solidworks |
[DesignModeler] Unable to Import Geometry | Alan212 | ANSYS Meshing & Geometry | 3 | March 17, 2015 11:26 |
[ICEM] geometry import problem | jayanth1990 | ANSYS Meshing & Geometry | 2 | October 8, 2013 14:25 |
how to import geometry file to turbogrid | summerverycool | ANSYS Meshing & Geometry | 0 | July 2, 2013 04:44 |
import geometry | circle | CFX | 0 | December 15, 2008 14:27 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
