Turbocharger compressor design
Old   August 18, 2016, 05:19
Default Turbocharger compressor design
Michael_K is on a distinguished road
Hi everybody,
I've started to test ANSYS workbench to get a feeling about automatic optimization procedure to get the ideal impeller geometry for specific boundary conditions.
Iīve found a webinar on ANSYS homepage called "improving turbocharger design" where the author explained a closed loop with Vista CCD-BladeModeler-Vista TF to get a first optimization for given flow conditions. Unfortenualy I struggled to create the same for my own. Two main steps I don't understand and don't let me proceed
- every time I connect BM with Vista TF and start the calculating procedure an error message stated that some geometrical parameters missing/canīt use from Vista TF
Does anybody know a good documentation that is describing the connection between these two components or describing the needs of TF?
- the webinar is showing a closed loop optimization with using a parametric model in BM and DesignExplorer(started at 24:30)
Does anybody know how I can implement this parametric model into BM? Do I need the Throughflow component?
Do I need I connection to TF to optimize the geometrical parameter to flow parameter?
Maybe anybody know a tutorial or similar that's explaining these or a similar optimization procedure.
Thanks in advance for your feedback.
Michael
Michael_K is offline   Reply With Quote
Problem extracting volume in a turbocharger Jambond STAR-CCM+ 54 January 31, 2017 08:49
Meshing issues in Rotor of Turbocharger Kru ANSYS Meshing & Geometry 0 August 2, 2015 14:09
turbocharger mohi Main CFD Forum 0 January 16, 2015 16:45
Custom turbocharger model. llmbs Main CFD Forum 0 May 1, 2011 05:12
Turbocharger simulation jai CFX 1 April 26, 2011 22:48
