Larissa C.Pinheiro
Rep Power: 11 ![]() |
Hi everybody,
I read tons of threads regarding integration in CFD-Post but I haven't found a straightforward answer for the question: "How can I change the integration variables in CFD-Post?". Is there a CEL construction which I can apply, or should I do the variable change manually? Problem definition: 2.5D natural convection annulus flow, with lower part of the annulus being the heater with prescribed wall heat flux and upper walls being the cooler with prescribed temperature. Further information: in my problem, I need to integrate dimensionless radial velocity through a dimensionless radial variable, since I have non dimensionalized the system. I already know I will use the lengthInt(variable)@ 1D location function. I have initialized the turbo mode in order to use polar/cylindrical velocities. Afterwards I will use this calculation result to assess the local nusselt number, and again I will need to integrate over a different parameter, in this case, the angle. Any short/long answers? Thanks in advance, any help or thread references would be really appreciated! |
cfd - post, change of variable, integration |
Plotting the Viscosity Contour in CFD Post | ashtonJ | FLUENT | 3 | June 2, 2015 12:06 |
CFD Post Streamlines better representation? | Dr. Flow Squad | CFX | 2 | January 20, 2014 13:48 |
How can I include scalable text in my images from CFD post? | ziggo | ANSYS | 0 | October 31, 2013 11:36 |
FEA results in CFD Post | delaneyluke | CFX | 1 | October 25, 2013 06:16 |
How to visualize Output Equation Residuals in CFD Post | rubin4ik | CFX | 2 | June 22, 2011 06:37 |
