August 15, 2016, 08:25 |
2way FSI for thin plate, mapping problem
Ali.E
Rep Power: 16 |
Dear all,
I am simulating a thin plate which has 0.2 mm (millimeter) thickness, 100 mm as length and 60 mm as width. Because of having very small thickness, mapping is failed. I have tried several ways to generate a fine mesh but they did not help me. It would be appreciated if you let me know your idea how to solve my problem. |
August 16, 2016, 06:29 |
umut
hi,
what is the exact error message. the problem may be arise due to large time stepping that creates negatives cells at fluent. try to reduce time step and add damping in mechanical solver. regards. |
August 16, 2016, 10:19 |
Ali.E
Rep Power: 16 |
Thank you very much for your answer. My problem is that the node and area mapped are not 100% as you can see below:
+--------------------------------------------------------------------+ | MAPPING SUMMARY | +--------------------------------------------------------------------+ | Data Transfer | | | Diagnostic | Source Side Target Side | +----------------------------------+---------------------------------+ | Data Transfer | | | Percent Nodes Mapped | N/A 100 | | Data Transfer 2 | | | Percent Nodes Mapped | 45 30 | | Percent Area Mapped | 28 27 | +--------------------------------------------------------------------+ |
Simple FSI (fluid structure interaction) Problem | kilroy | Main CFD Forum | 0 | January 7, 2015 14:42 |
Defining contact regions in FSI problem.!!! | sreemvlk | ANSYS | 0 | June 12, 2014 00:33 |
Regarding Remeshing in 2way FSI fluent | ajialiang | FLUENT | 3 | October 8, 2012 10:47 |
Problem with alpha1 in Fsi | Whyman | OpenFOAM | 0 | July 6, 2012 05:36 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
