Rep Power: 10 ![]() |
I inserted about 100 point surfaces in Fluent. However, when I get to CFD-Post, these points do not show up as locations from which I can pull data. Can someone tell me how to make sure the points move over with my data from Fluent or how to input a large number of points in CFD-Post in a pain free manner? I don't really want to enter them one at a time using Insert Point and I need them to be the same from one simulation to the next so Insert Point Cloud Random does not help me. Is there a way to create a large number of points using text in CFD-Post like you can in the console in Fluent? Thank you in advance for the help! |
umut
Rep Power: 0 ![]() |
hi,
as far as i know there is no way to send "points" from fluent to cfd-post. however, you can directly get your results from these points at fluent through "surface reports". another option may be creating points at cfd-post by scripting.. regards. |
Do you know how to do this by scripting in CFD-post? Or can you point me toward a good resource? Thank you!
Rep Power: 14 ![]() |
you have to create .CCL file and put your monitor points in it.
you can then import that CCL file in CFX for example: Code:
MONITOR POINT: wind_temp Coord Frame = Coord 0 Expression Value = volumeAve(Temperature)@wind Option = Expression END |
Pick a Node in cfd post | newbie384 | CFX | 3 | March 2, 2017 06:24 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 09:26 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
CEL mathematical functions in CFD Post | Jonathan | CFX | 9 | November 5, 2012 08:37 |
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? | ANT | ANSYS Meshing & Geometry | 2 | July 23, 2012 15:25 |
