July 11, 2016, 03:08 |
[solved] cannot open DesignModeler
Joe Smith
Rep Power: 10 |
I got the following errors as shown in the images attached when trying to open the DesignModeler component in the workbench in an empty project just created.
1. AnsysWB Module has stopped working 2. the geometry editor was closed abnormally 3. and unexpected error has occurred: Process with an Id of 1021888 is not running. I don't know why I have this problem. It seems the workbench I installed now can still open ansys project file created in other computer and show the results using the CFD-Post component. However, I still can't open DesignModeler to edit the geometry. May I ask how to fix this problem? Thank you! Last edited by oat; July 11, 2016 at 04:30. |
July 11, 2016, 04:29 |
Joe Smith
Rep Power: 10 |
OK, I solved the problem by following ntech's suggestions:
http://www.cfd-online.com/Forums/ans...tml#post500479 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
