frequential excitation of fluid
Old   July 4, 2016, 02:45
Default frequential excitation of fluid
mueller-p is on a distinguished road
Good morning,
for my new project I need a simulation of a deformable body which is filled with fluid.
In the sketch you can see the main problem. The body is excited on the top of the rubber roll with a defined path and frequent. I want to check as the fluid inside the body behaves. Besides if it is possible, I want to know the forces on the base of the steel frame. The damping factor and the spring stiffness of the rubber roll is known.
I know that the heigh and geometry of the steel frame has a significant influence of the resonance frequency and in the first step I want to simulate the system with a simple fluid pillar. After this I want to simulate other geometrys and heights of the steel frame.
I have no really experience in Ansys Workbench (my Version is 17.0), so I hope that you can give my any tips to solve this problem in Ansys.
Thank you very much.
Best regards from the north of germany.
mueller-p is offline   Reply With Quote
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 14:57
Fluid Structure Interaction Apollo FLUENT 8 July 7, 2004 18:54
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
