Error Massage "The solver failed with a non-zero exit code of : 2"
Old   June 27, 2016, 05:15
Default Error Massage "The solver failed with a non-zero exit code of : 2"
Ansys123 is on a distinguished road
Hello @ all,
I´ve got the following error Massage and I don't understand the Problem. Maybe I've deleted important data but I'm not sure. Thanks for your help.
Ansys.Core.Commands.UserReadableFailureException: The solver failed with a non-zero exit code of : 2
bei Ansys.Addins.Infrastructure.Rsm.Data.SolverTask.Re connect(IFullContext context, Boolean callingFromStopCommand)
bei Ansys.Addins.Infrastructure.Rsm.Data.SolverTask.Re connect(IFullContext context)
bei Ansys.Addins.Infrastructure.Rsm.Data.SolverTask.Wa itForFinish(IFullContext context, Boolean allowBreakWait)
bei Ansys.Addins.Infrastructure.Rsm.Data.SolverTask.St art(IFullContext context, ICanStartSolverTask startObject, SolverTaskStartTag startTag, SolverTaskSandboxInformation sandboxInformation, SolverTaskSecInformation secInputInformation)
bei Ansys.Addins.Infrastructure.Rsm.SolverTaskUpdateSt arter.StartUpdate(ICanStartSolverTask startObject, SolutionSettingsEntity solutionSettings, UpdateOptions updateOptions)
bei Ansys.CFX.CFXCore.Data.CFXSolutionSource.RunSolver (IFullContext context, Boolean forceResume, UpdateOptions updateOptions)
bei Ansys.CFX.CFXCore.Commands.UpdateSolutionCommand.E xecute(IFullContext context)
bei Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
bei Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext)
bei Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: The solver failed with a non-zero exit code of : 2
CommandName: CFX.UpdateSolution(Container="Solution 1", UpdateOptions=Set(HeldLicenseId=None, LicenseStatsId="ad6762ccb307473e9df075df70c00d37", DesignPointUpdateSolveManager=None, DesignPointUpdateQueue=None, MaxNumberOfCores=1))
bei Ansys.Core.Commands.CommandAsyncResult.WaitForSusp endOrComplete(Int32 milliSecondsTimeout, Boolean exitContext)
bei Ansys.ProjectSchematic.Data.ComponentTemplateEntit y.Update(IFullContext context, IProgressMonitor progressMonitor, DataContainerReference container, UpdateOptions updateOptions, List`1 downstream, List`1 allRemaining)
bei Ansys.ProjectSchematic.Update.UpdateImpl.updateCom ponent(IFullContext context, UpdateTask task, String trackToken)
bei Ansys.ProjectSchematic.Update.UpdateImpl.<>c__Disp layClass1d.<updateComponentAndDependencies>b__1b()
bei Ansys.ProjectSchematic.Update.UpdateImpl.executeWi thSelectedErrorBehaviour(Op op, UpdateTask forTask, Op opUponError)
bei Ansys.ProjectSchematic.Update.UpdateImpl.updateCom ponentAndDependencies(UpdateTask task, Boolean& didSomething)
Ansys123 is offline   Reply With Quote
CFX Solver does not write the results file and returns with error code 1 zeeshans CFX 17 November 16, 2023 12:11
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
