Maxwell3D Error
Old   June 13, 2016, 17:37
Default Maxwell3D Error
Negru Mihai
Mihi is on a distinguished road
I wanted to simulate the movement of steel plates induced by a permanent magnet. Any simulation I try to do it in Transient gives me the same error:
[info] Setup1 : Transient distributing Transient Solver
[error] This design cannot be solved using TDM (Time Domain Decomposition Method). This is because this design may include models using hysteresis, coreloss effect on field, or motionl setup using 'consider mechanical transient'. And the current version of TDM does not support model with using adaptive time stepping, or models using external circuits.
Does anyone know what this is?
I'm new here ... thank you.
Mihi is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
