May 27, 2016, 11:40 |
pipe flow with heat transfer
Michael Kraus
Rep Power: 10 |
Hello together,
I want to simulate the following case: water flows in a cylindrical pipe, 10 cm diameter, 1 meter long, wall thickness 1 cm, material copper, velocity inlet 0.1 m/s Inlet Temp. from water is 80°C. Wall Temp. at time = 0s is 20°C. The ambient air temperature is also 20°C = constant. I want the outlet temperature. I use ANSYS 16.2 - Student version. My main problem is how to create the geometry, the mesh and how to configure the setup. Additional: which sub-Program should i use: Fluid Flow CFX, Tranisient Thermal, or sth. else? Some good ideas would be nice. I am not completely new in CFD/ANSYS but still a beginner. (Dont blame me for stupid questions ) |
Reverse Flow In NanoFluid Based Double Pipe Counter Flow Heat Exchanger | nabidinhomessi | FLUENT | 0 | November 15, 2015 10:33 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[ANSYS Meshing] heat transfer through a pipe | cfdjunkie | ANSYS Meshing & Geometry | 3 | September 18, 2012 22:53 |
Conjugate heat transfer in reacting flow | ali_1364reza | OpenFOAM | 1 | May 30, 2012 15:15 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
