Expression, Kinetic Turbulence, Parallel to plane |
May 23, 2016, 05:34 |
Erik Hjertholm
When making a vector plot, one can set the projection to be tangential. Is it possible to do something similar with an expression? Like an expression for the tangential kinetic turbulence on a plane? |
kinetic energy, tangential, turbulence |
Turbulence kinetic energy and dissipation rate - problem with computation | Kozan | Main CFD Forum | 0 | March 6, 2015 05:04 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
parallel mapFields produces solution singularity at decomposition plane | florian_krause | OpenFOAM | 0 | October 23, 2009 04:40 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 10:52 |
