Geometry from autocad to ansys
Old   May 20, 2016, 22:28
Default Geometry from autocad to ansys
jimmy
catmelon is on a distinguished road
Hello Guys,
I am trying to import a AUTOCAD 3D model into ansys geometry. However, after I imported the dimension of the geometry in ansys is not right. The model I created in autocad is a 4x4x3 box while the dimension in ansys is only like 0.1007mx0.1007mx0.0755m.
Version of autocad 3d is 2013 and the ansys version is 16.
Thanks for your help.
catmelon is offline   Reply With Quote
[Workbench] Can i export an initial geometry from Ansys FE Modeler? DoBTo ANSYS Meshing & Geometry 0 October 15, 2015 11:47
[ANSYS Meshing] import geometry file to ANSYS rownak disha ANSYS Meshing & Geometry 3 October 6, 2015 03:05
[DesignModeler] geometry in ansys ice amir1372s ANSYS Meshing & Geometry 0 August 29, 2015 18:05
Creating geometry using journal file in AutoCAD? ripong Autodesk Simulation CFD 0 July 18, 2012 13:29
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 07:01
