simulate a gas filled pack
Old   May 10, 2016, 15:30
Exclamation simulate a gas filled pack
majid
maa_generals is on a distinguished road
hi my friends
i want to simulate a gas filled pack like a balloon and i want the inside volume of the deformed shape.
my problem is to simulate "gas pressure" inside and outside.
i was suggested to use "static structural" . but when i insert pressures , pack deforms unexpectedly(the directions and magnitudes of pressures of each position should change as pack deforms but they don't !)
i think this problem occurs because of ignoring pack flexibility and bad simulation of gas pressure.
also how can i get inside volume easily , because i should do that several times!!(i know how to get the volume by "fill" in geometry.)
i'm new to ansys and sorry if the question is so simple !
thanks for your suggestions...
maa_generals is offline   Reply With Quote
deformed geometry, inside volume, static structural
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a regenerator in stirling engine Walle FloEFD, FloWorks & FloTHERM 2 September 14, 2013 10:32
Centrifugal compressor modeling by real gas omidiut CFX 3 May 8, 2013 04:22
how to simulate velocity field of supersonic gas (400m/s) from a nozzle to a chamber CYMa OpenFOAM 3 December 15, 2009 22:31
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
