Is it possible to simulate a prototype of a Solar Heater? |
April 25, 2016, 13:01 |
Not just CFD analysis but the actual simulation using Ansys because our goal is to compare the data such as temperature and flow rate that will be obtained from the actual prototype(in real life) and data from simulating the prototype? If it is possible, how do you simulate it in Ansys? THis is our model created using SOLIDWORKS 2016 |
April 26, 2016, 01:58 |
Rep Power: 10 |
Yes. Open an account here https://support.ansys.com/portal/sit...CustomerPortal and start checking out tutorials and trainings. There are a bunch of them.
help needed on Design and Analysis of thermosyphon solar water heater | simran46 | ANSYS | 1 | July 9, 2014 14:19 |
[Other] Modification of multi region heater tutorial geometry | mukut | OpenFOAM Meshing & Mesh Conversion | 2 | October 4, 2013 21:59 |
.setSet problems | Grimoli | OpenFOAM | 9 | July 31, 2013 14:24 |
chtMultiRegionFoam: discrepancy on x-bounds on a region (heater) | raniisc14 | OpenFOAM Verification & Validation | 1 | August 30, 2012 18:25 |
Fluent Analysis of a Solar water heater | pavanmsd | FLUENT | 1 | April 12, 2012 06:33 |
