Mechanical APDL 16.2 Launch Fatal Error
Old   April 9, 2016, 18:05
Default Mechanical APDL 16.2 Launch Fatal Error
Maciej
Maciejz4 is on a distinguished road
After installation of Ansys 16.2 Student Edition on my workstation I cannot launch Mechanical APDL 16.2 or through Mechanical APDL Product Launcher 16.2. Workbench 16.2 works properly and I can open Mechanical APDL thorugh it, but I would like to fix the error with launching it directly.
So the error I get is:
"Could not create the file required to determine which products are to be displayed in the License dropdown list.
Path: C:\Users\ \AppData\Local\Temp\anslauncher_products162_ _0.xml
Error: Invalid file name 'C:\Users\ \AppData\Local\Temp\anslauncher_products162_ _0.xml' specified getuserprefs.
child process exited abnormally
This is fatal error; exiting."
I tried to find some solution in Google but none of them seems to work.
Please help
Maciejz4 is offline   Reply With Quote
Old   April 11, 2016, 10:04
Maciej
Well i fixed the previous error, and now anything but DesignModeler works correctly.
Whenever I try to create new geometry I get an error:
"The geometry editor was closed abnormally."
Does anybody know the solution?
My PC build is:
CPU: Intel Xeon e3 1275 v5 (Skylake)
GPU: Intel HD Graphics p530
RAM: 32GB (no ecc)
MB: MSI C236A Workstation
HDD: M.2 NVMe 512GB
OS: Windows 10
well I have no idea what the problem is. GPU supports Open-GL, drivers are up to date, as well as the windows drivers. Futhermore PC is only like a week old. I built it myself, but all the parts are compatible with each other.
I tried installing Ansys like 4 times already, trying all other methods I've found on the net, and none of them help.
Well if there's no solution, I think I'll try installing Windows 7 on another partition and try it there.
Please help.
Old   May 28, 2016, 13:13
ChaunceyHund
Chauncey is on a distinguished road
My PC build is:
RAM: 32GB (no ecc)
HDD: M.2 NVMe 512GB
OS: Windows 10
Please help.
it is so happy that I have seen your problem, I have been bothered by the exactly same problem for two days , to locate the problem, I tried to disable all the devices one by one then start ansys workbench. finally...when i disabled the integrated graphic card P530 and use discrete card only, the software worked!! your hardware is quite familiar with mine, i believe you will solve it in the same way...from a Bachelor in China
Chauncey is offline   Reply With Quote
Problem running perturbUCyl sen.1986 OpenFOAM 17 June 4, 2019 06:56
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
