Harmonic Analysis under electromagnetic simulation
Old   April 1, 2016, 00:44
Exclamation Harmonic Analysis under electromagnetic simulation
Vivek
Vivek81 is on a distinguished road
Dear All,
I have created a box geometry in ANSYS APDL. I used HF119 element and meshed its volume. In that 2 opposite faces are assigned with electric wall boundary and the other 2 opposite faces are assigned as Port-1 and Port-2.
But when I writes to find out its s-parameter command i.e., /sparm,1,2 then it gives the following error
"The eigen field at the port 1 is not found".
Please help to solve it out.
Vivek81 is offline   Reply With Quote
ansys, emag, harmonic analysis
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 10:16
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
1d analysis and simulation of gas turbine power plant sridhar.d009 FLUENT 0 September 28, 2010 08:46
1D analysis and simulation of gas turbine power plant sridhar.d009 Main CFD Forum 1 September 28, 2010 08:38
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
