Fikri Sharif
Rep Power: 0 ![]() |
Hi everyone, I have a problem regarding to heating surface in ansys polyflow. In order to define the heating, I need to use an equation as below which has a few variables that need to put values. The problem is when I use 300K as Tavg, Talpha(300K) which I think initial temperature respect to convection, then the results showed final temperature is about 298K. I tried also use other values for Talpha but the results always show lesser than Talpha value. Can anyone explain why this happened and how does this equation work? I thought final temperature should be higher than Talpha. For qo and h I just put reasonable values.
polyflow |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Comsol (4.3): convert parametric surface into block? | sgalaz | COMSOL | 0 | November 9, 2012 09:20 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
