Interface wall problem between outer tube face and external flow domain
Old   February 21, 2016, 08:45
Default Interface wall problem between outer tube face and external flow domain
Onur
Onurozcan is on a distinguished road
Hi all,
I have faced a problem that is relevant to Interface. Two faces are available to fuse one.But I couldnt do it.
with TUI commond, tried some command like fuse-face-zones and merge-zones but they couldnt have been created,
When I have tried both in TUI command and some messages occured in window like below
'fuse face zones'' : due to connectivitiy problem
''merge zones '':unable to merge
in Mesh interfaces window in Fluent, Wall_thickness_1 and wall_thickness_2 have been interfaced ''coupled'' but some problem have been occured like '' could not correct face handedness''
The system you see are combined 2 bodies in a part and shared topo have been applied in ''İmprints''
How can I resolve it?
Kind Regards,
Onurozcan is offline   Reply With Quote
PEM fuel cell simulation pchoopanya Mesh Generation & Pre-Processing 1 March 1, 2016 00:56
Interface wall problem between outer tube face and external flow domain Onurozcan FLUENT 4 February 24, 2016 08:07
[Commercial meshers] GAMBIT to OpenFOAM: "new patch wall is not an external face of the mesh" siavash7684 OpenFOAM Meshing & Mesh Conversion 1 June 28, 2015 17:34
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 15:54
2D Problem of External flow over an obstruction sandy_1982 CFX 27 February 3, 2013 06:07
