3D Nozzle Meshing in ICEM
Old   February 15, 2016, 17:07
Default 3D Nozzle Meshing in ICEM
aeroboy1 is on a distinguished road
Hi guys,
This is my first time trying to mesh a 3D volume in ICEM. I've had some experience meshing in 2D in the past. For a project I'm working on, I need to see flow through a convergent nozzle. I've tried following videos on Youtube and tried doing it but have got to nowhere. Had some questions for you all:
1. I have a domain around the nozzle. In ICEM, is that modeled as a body around the nozzle? I'm a little confused about that.
2. I did follow a video and got some sort of a mesh on my nozzle (I was just trying to teach myself and meshing it to see what it looks like). When I try to import it to FLUENT, it says 'critical error; error #f'. I've seen that error here on the forum before but can't seem to get rid of it. Checked my mesh and it says I have 99 multiple edges. Is that causing the problem? How do I get rid of the multiple edges?
Any help would be greatly appreciated guys. Thanks a lot!
aeroboy1 is offline   Reply With Quote
3d nozzle, ansys, fluent, icem
[ICEM] ICEM Blocking and Meshing - Flow over Periodic Hill Crank-Shaft ANSYS Meshing & Geometry 8 April 29, 2014 04:11
Fire FAME Hexa or Ansys Icem for Internal Nozzle Flow Doofy Mesh Generation & Pre-Processing 0 March 18, 2013 07:24
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 10:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 11:09
