Very High Drag Coefficients?
Old   February 2, 2016, 05:04
Default Very High Drag Coefficients?
Steven Goddard
spggodd is on a distinguished road
I'm not having much interest in my post in the Fluent forum so I thought I'd try this more general forum.
Please can you take a look at the following link:
http://www.cfd-online.com/Forums/flu...tml#post583347
Many Thanks
Steve
spggodd is offline   Reply With Quote
Old   February 2, 2016, 15:21
Dustin Ray
dray19 is on a distinguished road
I haven't used fluent to calculate drag coefficient, but from my experience if you use fluent to directly calculate some dimensionless number the results are off.
Have you tried calculating drag coefficient using the following equation
Cd=(2F)/(rho U^2 A)
F - drag force - which can be broken up into friction force (skin friction) and form force (pressure difference)
rho - density
U - velocity
A - Surface area
dray19 is offline   Reply With Quote
Old   February 2, 2016, 15:44
Steven Goddard
When you say 2F do you mean the sum of the pressure and viscous drag?
Old   February 2, 2016, 15:47
Steven Goddard
Also, I am using that formula using the total force output from fluent in the X direction.
This gives me a Cd value and then I am converting it to N/m^2 to match the paper I am comparing against by multiplying by the dynamic pressure.
The paper then give the formula: F = Cd* S / 1000 where S is area and Cd* is the modified drag coefficient.
However, I'm not sure why he has measured drag in N/m^2, is this common?
Old   February 2, 2016, 16:22
Dustin Ray
Coefficient of Drag is a dimensionless number, but after looking more at the paper you are referring to. It looks like their Cd is actually drag force per area.
Old   February 2, 2016, 16:38
Steven Goddard
Yes, I was taking the dimensionless Cd from Fluent and multiplying it by the dynamic pressure to give it units of N/m^2.
However, do you think the paper is suggesting some more simple such as taking the Force/Area?
Calculate Lift and Drag Coefficients CL and CD sven OpenFOAM 12 May 20, 2020 23:54
Induced drag, pressure drag, viscous drag. aleix.de.toro FLUENT 2 August 24, 2015 19:00
Can fluent get the lift and drag coefficients of the two walls (in different directio yuyuxuan FLUENT 8 January 10, 2014 21:13
Calculation of lift and drag coefficients Prachi CFX 3 August 14, 2007 15:05
Drag and moment coefficients Armando CFX 0 July 26, 2007 18:55
