FSI. Fluent divergence issue due to Dynamic Mesh
Old   January 26, 2016, 02:31
Default FSI. Fluent divergence issue due to Dynamic Mesh
Svensen is on a distinguished road
I have a STEP file with a geometry of cerebral artery. Using operation SurfaceFromFaces a surface of the vessel wall was extracted to create a solid region with a thickness of 1 mm.
The boundary and initial conditions were applied for fluid, and FluidSolidInterface was defined for solid. Dynamic Mesh option was enabled in Fluent and regions of deformation were defined.
All settings were using settings from this lesson on Youtube: https://www.youtube.com/watch?v=DGPmyGFnzhA
However during computation of FSI task I've got an error. For short, Fluent got a divergence in a solution(divergence detected in AMG solver: x-momentum).
But if I run Fluent without coupling it with Transient Structural and without Dynamic Mesh option the there are no errors any more.
Maybe someone had the same error before and can help me to solve it.
A project archive is in cloud storage (too big, about 50 Mb): https://yadi.sk/d/qESZIeqIne3gf
Log of an error is in attached file.
Thanks.
Svensen is offline   Reply With Quote
Old   January 27, 2016, 14:18
saikrishna
krishna18 is on a distinguished road
Change your pressure outlet to outflow and try again and check about the coupling part you will not get divergence
If possible try to reduce the time step too
krishna18 is offline   Reply With Quote
Old   January 28, 2016, 02:41
I'm sorry, but your recommendations don't work...
ansys, fluent, fsi 2-way coupling, transient structural
Fluent dynamic mesh 'remeshing' method for pyramid elements DarrenC FLUENT 14 December 11, 2015 05:58
Divergence using Dynamic Mesh renatovj FLUENT 1 January 5, 2015 19:26
Postprocessing issue with dynamic mesh? ghost82 FLUENT 1 November 2, 2012 11:06
Dynamic mesh issue moloykb FLUENT 8 September 24, 2012 13:07
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
