January 11, 2016, 11:07 |
tube/tubesheet connection no convergence
Simon1989
Hello everyone,
i am working on my bachelor thesis. It is about the connection between the tube and tubesheet by using high internal pressure. I have the problem that there is no convergence when increasing the pressure. It´s a weird that the model is working at a pressure of 1600 and 1700 bar but not at a pressure of 1601 ( highly distorted elements ...). If you adjust a high tangent modulus it will work for a high pressure input. But i like to do it with a tangent modulus of zero. Has anyone a solution ? fini /clear /FILNAME,HYDAUFWEITEN /PREP7 !Geometrie Eingabeparameter[mm] dia=10 !outer radius tube ti=1 !wall thickness tube gap=0.1 !gap between tube and tubesheet !Aufweitdruck pi=2600 !pressure in bar !Geometrie berechnete Radien RAA=40 !outer radius tubesheet RAI=dia/2+gap !inner radius tubesheet RIA=dia/2 !outer radius tube RII=dia/2-ti !inner radius tube !Meshing nU=50 nRP=30 nRR=3 !Model POINTS tubesheet K,1,RAI,0,0, K,2,RAA,0,0, K,3,0,RAA,0, K,4,0,RAI,0, !Model POINTS tube K,5,RII,0,0, K,6,RIA,0,0, K,7,0,RIA,0, K,8,0,RII,0, K,9,0,0,0, !LINES L,1,2 LARC,2,3,9,RAA L,3,4 LARC,4,1,9,RAI L,5,6 LARC,6,7,9,RIA L,7,8 LARC,8,5,9,RII !AREAS AL,1,2,3,4 AL,5,6,7,8 !Element Data et,1,plane183 et,2,CONTA175 et,3,TARGE169 !KEYOPT,2,5,1 !KEYOPT,2,9,1 ! Material 1 mp,ex,1,212000 mp,nuxy,1,0.3 !tb,biso,1 !tbdata,,300,0 !Material 2 mp,ex,2,200000 mp,nuxy,2,0.3 tb,biso,2 tbdata,,268,0 !Real Konst. Target Element r,10,RAI !Meshing Sizing lsel,s,,,2 lsel,a,,,4 lsel,a,,,6 lsel,a,,,8 lesiz,all,,,nU alls !tubesheet, radial lesiz,1,,,nRP,10 lesiz,3,,,nRP,1/10 !tube, radial lesiz,5,,,nRR lesiz,7,,,nRR !Meshing Area 1 und Materialübergabe asel,s,area,,1 aatt,1,,1, CM,_Y,AREA ASEL, , , ,1 CM,_Y1,AREA CHKMSH,'AREA' CMSEL,S,_Y MSHKEY,1 AMESH,_Y1 MSHKEY,0 CMDELE,_Y CMDELE,_Y1 CMDELE,_Y2 alls !Meshing Area 2 und Materialübergabe asel,s,area,,2 aatt,2,,1, CM,_Y,AREA ASEL, , , ,2 CM,_Y1,AREA CHKMSH,'AREA' CMSEL,S,_Y MSHKEY,1 AMESH,_Y1 MSHKEY,0 CMDELE,_Y CMDELE,_Y1 CMDELE,_Y2 alls !contact real,10 lsel,s,,,6 nsll,,1 type,2 esurf alls lsel,s,,,4 nsll,,1 type,3 esurf alls !Boundarys and Forces DL,1,,UY,0 DL,3,,UX,0 DL,5,,UY,0 DL,7,,UX,0 /solu !ANTYPE,4 NLGEOM,on NSUBST,500 kbc,0 TIME,1 SFL,8,PRES,pi*0.1 LSWRITE,1, Time,2 SFLDELE,8,PRES LSWRITE,2, lssolve,1,2,1, |
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 08:24 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 11:45 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
