Bladegen: struggling with the bladegen import wizard
Old   November 30, 2015, 14:16
Exclamation Bladegen: struggling with the bladegen import wizard
dale154 is on a distinguished road
Hello, i'm aiming to model a rotor fan.
I have my completed blade geometry and i'm struggling with the bladegen import wizard. I have searched around for help but there doesn't seem to be much on it and the 'help' isn't too great. So i'm hoping someone can help.
I import my IGS file of the blade. It shows my blade made up of nine individual profiles as expected. For the hub curve do i select the hub profile and likewise for the shroud the tip profile? If not what should they be.
I'm also unsure of the meridional definition part (perhaps due to the previous parts), i'm hoping someone can maybe explain a little of what it wants for this section.
I appreciate your help very much,
Dale.
dale154 is offline   Reply With Quote
ansys, bladegen, cfx
[Other] BladeGen Data Import Wizard kariz ANSYS Meshing & Geometry 9 August 28, 2018 16:07
[Other] Problem with BledeGen Data Import Wizard kariz ANSYS Meshing & Geometry 1 May 5, 2014 09:06
[BladeModeler] Bladegen data import wizard ArslanOZCAN ANSYS Meshing & Geometry 0 November 6, 2013 03:58
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
