DesignXplorer - Kriging Response: how many refinement points should be introduced?
Old   November 5, 2015, 14:10
Default DesignXplorer - Kriging Response: how many refinement points should be introduced?
Liam
LiamH is on a distinguished road
Send a message via Skype™ to LiamH
Hey Experts,
I was wondering if someone could give me some advice concerning DesignXplorer.
In workbench, I am modeling a nozzle which is coupled with the DesignXplorer application and I am trying to get an idea of how the nozzle behaves when I change the geometry and vary the flow rate between 1000<RE<100,000. The model is in 2D to make it very fast.
After running the base model, I got bad statistical results (Simulations made sense however) so I went with the recommended Kriging response which requires additional refinement points and verification points to increase the quality of fit.
My question is how many refinement points should I push into this model before it is likely necessary to switch to another type of response method. In the tutorials, they used about 4 points but this is way too little. I am sitting at ~65 points generated so far and I am not getting very close to the relative % error of 5.
Any thoughts?
Cheers!
Liam
LiamH is offline   Reply With Quote
Old   April 19, 2020, 00:08
Default Does it influence very much for the refinement points
hitzhwan is on a distinguished road
Originally Posted by LiamH View Post
Hey Experts,
Any thoughts?
Cheers!
Liam
hitzhwan is offline   Reply With Quote
ansys, cfd, designxplorer, nozzle, optimization
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] Collapsing Layers Tim_Simon OpenFOAM Meshing & Mesh Conversion 5 August 2, 2015 23:51
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
