How to change fluid to solid / solid to fluid in Ansys workbench 16 (CFX)
Old   November 1, 2015, 07:20
Default How to change fluid to solid / solid to fluid in Ansys workbench 16 (CFX)
Siew John Win
johnwin200 is on a distinguished road
Hello Everyone,
First, i import geometry from solidwork to workbench 16 (CFX).
After mesh and setup, i found the problem such as:
1) Inside wall was fluid and inside room was solid.
Did anyone know how could i change it from fluid to solid and solid to fluid in Workbench CFX?
Thank You.
johnwin200 is offline   Reply With Quote
Old   November 1, 2015, 10:05
fresty is on a distinguished road
If you wouldn't want to go back to your 3D Software then I guess you would have to apply the some boolean operations in ANSYS DM (Design Modeler)..
fresty is offline   Reply With Quote
Old   November 4, 2015, 01:02
Siew John Win
Thank fresty, but both of 3D Software and boolean operations don't work for it.
Old   November 4, 2015, 08:11
Hard to imagine how you could not alter/ reverse the domains in the 3D software you initially used to create the entire model... if you could provide more details to probably sort this out..
ANSYS CFX/Mechanical - fluid domain error amsys CFX 1 September 15, 2015 12:12
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
How to read .msh file in ANSYS CFX workbench?? b.shuvayan CFX 3 October 29, 2012 07:27
FSI in Ansys Workbench + CFX v.11 nasdak CFX 3 June 22, 2009 09:44
