How to Import Volumetric Loss from Maxwell to ANSYS Mechanical 2013
Old   October 29, 2015, 05:49
Default How to Import Volumetric Loss from Maxwell to ANSYS Mechanical 2013
Moe
mtajeldin is on a distinguished road
Hello everyone,
First, I imported a geometry from ANSYS Maxwell 14.0 in STEP format for axisymmetric cylindrical about Z drawn in 2D design for simplicity and imported the Thermal Link file, after running the electromagnetic simulation, in xml format.
In ANSYS Mechanical, I used Steady-State Thermal module and when trying to import the geometry, it automatically creates a rectangular coordinate geometry in 2D and lost the cylindrical axisymmetric system generated by Maxwell.
Question 1: it there a way to tell ANSYS Mechanical that the imported geometry should be as it is in cylindrical coordinates?
Question 2: next, in ANSYS Mechanical 15.0, 2013, I could not add/find 'Imported Heat Generation' component to import the Volumetric Loss through Thermal Link file.
Could you help me figure out how to figure it out, please?
I watched the webinar below but it was for Mechanical 2009 where you could add from Steady-State Thermal, right click -> 'Imported Load' -> 'Imported Load Transfer Summary' but I could not find it in Mechanical 2013.
http://www.ansys.com/Resource+Librar...ysis+-+Webinar
Thanks alot,
mtajeldin is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Ansys Mechanical 14.0, Axi-symmetric condition in Ansys Mechanical? SteveFinnan Structural Mechanics 1 April 8, 2014 16:33
[DesignModeler] Import points into Ansys Tonnedi ANSYS Meshing & Geometry 0 July 29, 2013 02:33
problem in import ANSYS mesh sheryl CFX 2 April 30, 2005 22:30
how to analyze mechanical energy loss of fluid? Lcw FLUENT 3 October 27, 2004 12:22
