[Workbench]Parametric study. Excel component with multiple rows of values
Old   October 17, 2015, 23:12
Default [Workbench]Parametric study. Excel component with multiple rows of values
Jacob
kubawlo is on a distinguished road
I want to create a parametric study in workbench-->fluent.
The study involves pressure-drop CFD calculations as a function of velocity.
How to create an Excel output parameter being rows of different velocities (which will be transferred as a fluent boudary condition) and then Excel input parameter being calculated pressure drop (see attachment - how to fill the B column)? All in/out values must have the dimension.
I have managed to create excel input and output, but with one value only. I had to add more values manually to the velocity parameter in Design Point Table and the single value inputted to Excel was that marked with "Current".
Second question: how to set the condition that Fluent starts calculation from the solution initialization every single time when updating "Design Points"?
kubawlo is offline   Reply With Quote
Parametric Study - Multiple Configurations in ANSYS CFX kskong CFX 1 June 7, 2016 09:22
exchange of parameter values between component systems in Workbench la7low CFX 0 January 17, 2011 11:28
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 12:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 12:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
