October 17, 2015, 19:37 |
Unidirectional fiber direction in ansys 16.2
i'm working on modeling a thin airfoil section with several layers of UD fiber. I have created the airfoil as 3 thin surfaces stacked up. I've set UD fiberglass/epoxy as the top and bottom layers, and an anisotropic epoxy as the middle layers. I cannot seem to find a way to orient the fibers in the directions I'd like. I can only assume they are at present oriented directly along the X axis. |
ERROR: Flow direction on the boundaries must not be tangential to the boundary. | turbomax | CFX | 3 | October 27, 2024 07:19 |
Command Line Run for ANSYS | Liaquat | ANSYS | 11 | April 19, 2018 10:49 |
Very low coefficient of Lift for a 2D airfoil (Ansys) | aptahaney | FLUENT | 1 | June 16, 2015 11:14 |
Changing inflow velocity direction deteriorates lift and drag | ziggo | FLUENT | 3 | July 24, 2013 09:39 |
[ICEM] Volume Direction Error in Ansys ICEM | sebastian | ANSYS Meshing & Geometry | 0 | December 15, 2009 10:24 |
