October 9, 2015, 05:59 |
Particles in air flow
Rep Power: 11 |
Hello.
We are working on a bachelor about optimization of an ejector. A quick overview of the structure: There are two inlets and an outlet. In one of the inlets water flows, which is delivered by a pump. In the second inlet particles/powder will be sucked up from a bag. The water and the powder is mixed and leaving the ejector through the outlet. The issues are: how do I add both powder and air at the other inlet? I use CFX. Best regards Anette Student Engineering College of Aarhus Denmark Last edited by BachelorM7; October 14, 2015 at 03:14. |
October 13, 2015, 10:19 |
Rep Power: 13 |
First thing, you would need to post the query in CFX forum. Apart from that a rough sketch or model would evoke much better support. You would have to use a mixing model simulation. There are reasonable amount of tutorials online relevant to your work.
October 14, 2015, 03:15 |
Rep Power: 11 |
I'm new in here, so I don't know have to post a picture.
Yes, but I don't know which mixing model? |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 22:33 |
flow Maldistribution in air conditioning | rgd | FLUENT | 0 | July 29, 2013 12:34 |
DPM for steady flow with unsteady particles tracking | yahya | FLUENT | 0 | March 28, 2013 14:28 |
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 17:30 |
How to set correct mass flow rate for lagrangian particles ? | sankarv | OpenFOAM | 0 | April 19, 2010 12:40 |
