Error:You have chosen an invalid result for the current analysis |
September 27, 2015, 20:51 |
Vasilis Kar
Rep Power: 11 |
I am running a steady-state thermal analysis on ansys 16.2, and this is the first time I am using this program. I have imported my geometry from creo parametric 3.0, I have set all the necessary materials and boundary conditions and when I run the solver I receive the following messages: "You have chosen an invalid result for the current analysis" 3 times, with the following associations: "Project>Model>Steady-State Thermal>Solution", "Project>Model>Steady-State Thermal>Solution>Solution Information>Temperature - Global Minimum" and "Project>Model>Steady-State Thermal>Solution>Solution Information>Temperature - Global Maximum". How invalid a result can temperature be in a thermal analysis problem? |
December 4, 2022, 21:13 |
Vish
Rep Power: 14 |
Hi Vaskar
Were you able to solve this problem? Please advice. Thank you Vishal |
ansys 16.2, error, thermal analysis |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 15:33 |
how to make analysis from the result in fluid flow (CFX) ansys workbench 14 | wan11 | CFX | 3 | December 18, 2014 20:25 |
compare theoretical, experimental, analysis result | ekfzha55 | CFX | 1 | October 25, 2013 07:51 |
how do i analysis result on phoenics | fredson | Phoenics | 0 | March 3, 2008 09:58 |
Unsteady Result Analysis | HAR | FLUENT | 2 | August 9, 2006 11:04 |
