Camila
Rep Power: 11 ![]() |
Hello people!
I'm kind of new on CFD, and I'll do a 3 phase CFD simulation (gas-liq-solid) in an UASB bioreactor (do not considering reaction). I have tried some strategies for meshing (on ICEM with hexa mesh) and I had problems with quality... Now I'm trying to use Ansys meshing or ICEM with tri/tetra mesh.... The point is that there are just to many options of meshing strategies, and I'm lost... If you could help me I would be really grateful! First of all: Ansys meshing or ICEM? Wich one should give me the best results for a good meshing? (considering that I will start with a coarser mesh and refine after a few times, to get a mesh independent result at Fluent). Secondly: with strategy should best fit my geometry that is attached? Thank you So much! Camila |
meshing 3d, reactor design |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp | Crank-Shaft | ANSYS Meshing & Geometry | 0 | January 11, 2013 05:48 |
meshing strategy for IC engine. | Upendra | ANSYS Meshing & Geometry | 1 | September 30, 2012 02:32 |
[ANSYS Meshing] Meshing strategy for External Flows | Hybrid | ANSYS Meshing & Geometry | 0 | January 24, 2012 14:27 |
Meshing in reactor with mutistage impellers | GOPINATH87 | Main CFD Forum | 0 | August 21, 2011 14:07 |
