Negative cell volume. Where?
Old   August 19, 2015, 22:44
Default Negative cell volume. Where?
Kegan Leckness
KeganLeckness is on a distinguished road
Hi all,
I am receiving the error described in the thread title from my Fluent/ANSYS two-way FSI analysis. I have multiple fluid domains separated by solid domains. How can I determine where this volume is detected?
Regards,
Kegan
KeganLeckness is offline   Reply With Quote
Old   August 30, 2015, 02:06
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
check the contours of mesh
Far is offline   Reply With Quote
Old   September 15, 2015, 18:04
Kegan Leckness
Thank you for your suggestion.
Won't checking the contour only show me the elements on a particular face? I suspect the cell(s) with negative volume are in the interior of the fluid domain.
I've plotted a Volume Rendering of variable: cell volume derivative.
There doesn't seem to be any good definition of what this variable represents in the HELP documentation or in the forums. Some of these values are reported as being negative near the FSI interface (at the location I suspect poor elements will occur). Is this the best way to search for poor quality elements in CFD-Post?
Kegan
Old   September 16, 2015, 20:30
pja
pja is on a distinguished road
Kegan
If there is a way to list the element Jacobians you should be able to detect negative volumes by identifying the Jacobians which are negative.
pja is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
Warning: negative cell volume detected! boboroo FLUENT 7 February 11, 2018 04:38
Negative Cell Volume with moveDyMEngineMesh with Foam Extend 3.0 RJ87 OpenFOAM 2 May 8, 2014 13:13
Negative cell volume problem schuny FLUENT 8 April 10, 2012 06:16
negative cell volume alfin FLUENT 2 January 19, 2006 21:17
