how to record the moment at every time step !!!! |
August 17, 2015, 11:59 |
abuabdellah
Rep Power: 13 |
i am simulating 2d darriues VAWT,i want to record the torque (moment) at every time steps ...
what do you have pros?? |
August 17, 2015, 19:17 |
Rep Power: 14 |
You can just use Monitor points. The chart will show moment at each timestep as you run your simulation. You can export the chart result later on as well and use it how you want it. Cheers KAPI |
moments, torque coefficient |
interDyMFoam with VOF + 6DOF instable | pbalz | OpenFOAM Running, Solving & CFD | 11 | October 9, 2020 06:19 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 04:41 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
