No static structural in Workbench
Old   August 12, 2015, 10:39
Default No static structural in Workbench
N/A
drachen is on a distinguished road
My Ansys version is 14.5 on Windows 7.
Under the Workbench -> Toolbox, Static Structural does not appear as expceted. However, the Static Sturctural is listed under Toolbox Customization. My question is what happens to it, and how to build a Static Structural system in the case?
Many thanks in advance!
drachen is offline   Reply With Quote
Old   August 12, 2015, 21:18
Kapi is on a distinguished road
Hi drachen,
Under Toobox customization, go to Static Structural and you will find a small box on left side if it. Select that box and it will come as Tick Mark. Once you have the Tick mark, you will be able to see static structural under your Toolbox
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   August 13, 2015, 06:59
N/A
Originally Posted by Kapi View Post
Hi drachen,
Cheers
KAPI
Thank you very much for the reply!
However, the fact is that only Fluid flow (CFX), Fluid Flow (Fluent) and IC Engine appeared under the Toolbox, even I checked all the marks. It only appears/disappears under the Toolbox when choosing one of the three above, no work for the rest. I really do not know the reason behind. Is it about my lisense?
Cheers
Drachen
Old   August 13, 2015, 19:25
License could be possible cause.
do You have mechanical License? If not then you will not be able to use it.
Check type of your license from "Serverr Anslic_Admin Utility"
If you have license then try again and save it
Cheers
KAPI
Old   August 14, 2015, 07:53
N/A
How to check the type of the license in my computer, are they different? What I know is that I can use Fluid Flow(Fluent) at least.
Cheers
Drachen
Old   August 16, 2015, 19:17
To check all licenses you have
goto: "Start" > "All programs" >"Ansys, Inc. License Manager" > "Server Anslic_Admin Utility" > "View Status/Diagnostic Options" > Display the License Status"
static structural, workbench
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
Solution not convergin in ansys workbench static structural amit2590 Structural Mechanics 1 May 16, 2014 18:19
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
