geometry from fluent to solid works
Old   August 1, 2015, 04:41
Exclamation geometry from fluent to solid works
frety
jose_zola is on a distinguished road
Hello all,
I did some work on creating a heat exchanger by changing the porosity inside a volume(i created a cube and chaged its porosity by a udf function). and i start the calculation and modeled the velocity inside the volume. it was coorect. now i need to copy this heat exhanger(after i changed the perosity of it) to solid works in order to be able to print it in 3d. anyone have an idea on how to do this?
jose_zola is offline   Reply With Quote
flow, fluent - udf, heat exchanger, porosity, solid works
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
Generating 2D geometry for fluent himanshu28 FLUENT 4 March 28, 2013 11:00
Import Soliworks geometry to Ansys Fluent 12.0 nunolopes FLUENT 0 October 7, 2010 12:24
Geometry with fluent Vito Di Virgilio FLUENT 0 April 9, 2007 10:52
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
