Generating output data on AQWA Naut
Old   July 2, 2015, 03:37
Default Generating output data on AQWA Naut
aa
afitriadhy is on a distinguished road
Hi All AQWA users,
I run simulation in AQWA GS for AQWA Naut for turret model with six cable; and I got printed output data for each mooring-lines.
However, when I run eaxmple file from folder training of AQWA (Tanker+Buoy with 4 mooring-lines), initially I can not get the output data; However, I put command ''PTEN1'', the output then appears. Unfortunately, it shows only one mooring line No. 5. (pls see the attached file)
The first question is how to print out the output of all 5 mooring-lines from that example file.
The second question
I then open cable dynamic file as shown in the attached file; fortunately, the mooring-line force no. 1, 2, 3, 4 and 5 can be seen in the plotting graph.
The question is, how the output data from the display graph can be obtained? (pls refer to the attached file).
I do believed that the are many expert users willing to share answering my question.
Thanks in advance.
rgs,
Fit
afitriadhy is offline   Reply With Quote
output data on aqwa naut
Improved solver data output / tracking / visualization chriss85 OpenFOAM Running, Solving & CFD 1 May 13, 2015 08:55
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 05:46
How did I output data ? Andy Chen CFX 4 August 19, 2009 09:22
where is output data file[PHOENICS] DSF Main CFD Forum 1 June 8, 2000 10:15
