Guideline for grid density of imported layout file in Icepak
Old   June 23, 2015, 05:58
Unhappy Guideline for grid density of imported layout file in Icepak
Ivan Chi
ivanchi is on a distinguished road
Hi
The layout file can be imported into a block in Icepak, like substrate or PCB.
But I found the Grid Density of the layout file plays an important role in the results, I have tried grid 100x100 200x200 ....... 2000x2000.
There are so much larger difference between these cases.
I think the grid density is base on how large of the package or PCB.
Does someone have the Guideline for grid density of imported layout file?
thanks!
ivanchi is offline   Reply With Quote
Old   October 13, 2015, 09:24
Default Grid Density
Pramodh.J
Jupudi.pramodh is on a distinguished road
Send a message via Skype™ to Jupudi.pramodh
As you mentioned, Grid density plays an important role in predicting the results in case we've imported traces of a PCB (into a block representing PCB). The finer the PCB, the more time solver takes to calculate the metal fractions.
I guess the default values set in Icepak would be 200X200. depending on size of your grid and traces, we'll have to alter the values. As far as i've experienced, I was using 750x750 as grid density and didn't find much difference on still finer numbers.
Any ways, just the way we do mesh optimization study (Grid independent study), performing a couple of iterations to freeze the grid density would be a safe practice..
Cheers,
Pramodh J
Jupudi.pramodh is offline   Reply With Quote
grid, icepak, layout, mesh
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
