How to combine ANSYS Fluent and Structural analysis? |
June 16, 2015, 18:12 |
Diwakar
Rep Power: 11 |
Hey guys...i'm working on a turbine blade analysis with ANSYS...in which i'm going to first analyze the blade model in ANSYS fluent to get temperature distribution over the blade surface then i want to import the temperature from ansys fluent to ANSYS structural and apply rotational velocity to the blade to get the structural stresses on it...
I created a simple blade model in SolidWorks and analyzed it in Fluent...then i analyzed that model in structural by giving it a rotational velocity with x-axis as rotational axis...then I tried combining Fluent with structural...but after that the results in ansys stuctural showing wrong... the thing is when i do structural analysis separately...the stress results are reasonable...but when i import the temperature in ANSYS structural i.e. combine the two analysis then the structural results come up wrong... so can anybody please tell me how to combine ANSYS Fluent with ANSYS Structural? |
June 17, 2015, 06:05 |
Jakub
Rep Power: 12 |
hi Diwakar,
Do you use Workbench or transfer results by hand? Are the units correct (Kelvin, Celcius)? Workbench usually transferes results automatically, and i think your problem could be solved using it. |
June 18, 2015, 13:07 |
Diwakar
Rep Power: 11 |
https://goo.gl/photos/ejRN11Tsj9UGqHs97
https://goo.gl/photos/Ryfy1HxP93vKjDyr7 https://goo.gl/photos/EoFD71PmFmNZ6vri9 https://goo.gl/photos/Qbe6BRp6yFRCGWNg9 https://goo.gl/photos/GWKWqUuQnTZtyLcx9 Please take a look at above images and u will get a clear idea of what i'm doin... i have applied rotational velocity to the whole blade along x-axis... images show the structural stress results with structural analysis done separately and also stress results when i combined Fluent and Structural...in combined analysis i imported blade body temperature obtained from Fluent...the air domain which surrounds the blade is suppressed in structural analysis as it cannot be used there anyways... but Combined analysis shows wrong structural stress results...and when i suppress the imported temperature the stress results are right... Can anyone please resolve this problem??? |
1 way and 2 way FSI in ANSYS Workbench with Fluent and ANSYS Structural | jwillie2000 | FLUENT | 6 | November 27, 2017 00:21 |
Ansys structural and fluent for FSI | assafwei | FLUENT | 1 | June 20, 2014 11:56 |
Coupling Error Between ANSYS Transient Structural and Fluent | Ayuba | ANSYS | 1 | March 18, 2014 10:30 |
Acoustic Analysis using Fluent and ANSYS mechanical | ankit1512 | ANSYS | 0 | November 10, 2013 19:46 |
From Fluent 6.23 to ansys 12 structural | Rich1979 | FLUENT | 0 | April 18, 2011 10:40 |
