Harmonic analysis- loads
Old   June 5, 2015, 09:33
Default Harmonic analysis- loads
Robert
RobertW is on a distinguished road
I prepare the APDL model of the device.
The device is fixed to the base plate.
The device has some piezo-electric (PZT) elements attached to it.
The PZTs once powered cause the device to vibrate.
The Ansys model for such a device is ready (also for simulation of its behaviour when the PZTs are powered with the fixed AC voltage value but of varying frequency).
However, I would also like to add some external force acting on this model (while the device vibrates due to PZTs action). The force would be a quick up-down movement - reciprocating motion (outer source of vibration), which would simulate shaking of the entire device- as the device would be placed on the table which does quick up-down movement.
Now, there are my kind questions.
1. Is vibration of the model/device caused by powering of the PZT considered as the load- in Ansys? My understanding is - yes. But not sure.
2. If yes to question 1, then can I apply extra force causing interference vibration (described before question 1)? I ask about it, as when I read the Ansys handbook as the guidance for building a model for a harmonic analysis in Ansys, I find that (citing): A harmonic analysis cannot calculate the response to multiple forcing functions acting simultaneously with different frequencies. ... Post 1 can be used to superimpose these two loads cases for the total response.
3. As I am relatively new to Ansys programming, I would like to ask kindly for a little advice regarding to applying an external load/vibration to the device.
If I would like to apply the force/load where described model/device moves up-down quickly (like shaking- description above question 1) what would be the best option to simulate this?
Thanks.
Robert
RobertW is offline   Reply With Quote
harmonic, load
How to implement a sensitivity analysis for certain items Mason liu CFX 10 August 17, 2017 09:46
Harmonic Analysis woth Displacement Loads giorgio.parise Structural Mechanics 1 February 25, 2015 09:09
Acoustic Analysis using Fluent and ANSYS mechanical ankit1512 ANSYS 0 November 10, 2013 19:46
Acoutic fan analysis arunraj FLUENT 0 October 4, 2012 06:54
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 13:58
