May 27, 2015, 12:22 |
Ansys design points
Jarosław
Rep Power: 15 |
Hello all,
I would like to use parameters to calculate different angles of attack. I defined in design modeler rotation of the aircraft body and marked parameter for that value but when i update all design points, geometry is updated only in design modeler but not in meshing section . It uses old geometry and mesh for calculations. Do you have any clue why its not updating geometry for meshing but updating it in design modeler? How i should activate automatic updates in meshing section ? Thank you in advance |
How to Connect Points in Design Modeler to make airfoil profile (2D) | andrew_diablo | CFX | 3 | July 7, 2017 06:23 |
ansys design explorer | tmeysam92 | ANSYS | 1 | January 27, 2015 15:39 |
Ansys 14 WB problem with updating design points | vitulaaak | ANSYS | 1 | September 5, 2012 11:47 |
Ansys Design Modeler complex geometry | natantyt | ANSYS Meshing & Geometry | 1 | October 17, 2011 09:57 |
Any other way of converting a multi part to a single part avoiding ANSYS Design Model | LusoMundo | ANSYS Meshing & Geometry | 1 | May 14, 2009 15:35 |
