How to split face using circle?
Old   May 22, 2015, 09:04
Question How to split face using circle?
spitf1re is on a distinguished road
Hey!
I am new to ANSYS and I have encountered a big issue :P I want to split a face (which is a ring) into two rings. I figured out that I would draw a Sketch on a plane of that ring and then use "Face Split" function to split it, just as I did it with points numerous times.
After I draw the circle I tried to use "Face split" but the system does not allow me to pick the sketched line as "Tool". I also tried using "Line from Sketch" function, but it didn't help.
What should I do? Here's the pic
EDIT: found the solution, please delete the thread
spitf1re is offline   Reply With Quote
Old   November 23, 2015, 12:42
Default What's the solution?
Andhros Guimarães Silva
Andhros is on a distinguished road
That's also my problem, it would help me a lot sharing the solution...
Andhros is offline   Reply With Quote
Old   February 26, 2019, 06:55
Richard Jenkins
jenkinsr is on a distinguished road
Can you please post your solution? Other people have the same problem (including me) and would like to know how you did it?
jenkinsr is offline   Reply With Quote
Old   March 8, 2019, 05:26
Taylor Long
triple_lor is on a distinguished road
In Gambit, you can split surface with edges.
triple_lor is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
