Equivalent thermal conductivity calculation
Old   May 20, 2015, 14:14
Exclamation Equivalent thermal conductivity calculation
Ivan Chi
ivanchi is on a distinguished road
I am a junior IC thermal engineer.
In order to reduce the quantity of meshes, I am trying to build equivalent thermal model.
I have survey some papers about this topic : http://goo.gl/hXZ05r
But it still exist some errors, so I wanna calculate equivalent thermal conductivity using icepak directly.
My concept is setting X & Y condition into adiabat then given power from Zmin, the Zmax is fixed temperature.
Probe the temperature of Zmax and Zmin, (ZmaxT-ZminT)/Power = thetaZ
Then the equivalent thermal conductivity of Z direction can be calculated.
But now I'm facing an issue, if the geometry is plated-through holes (PTH), like this : http://goo.gl/2dSIZl
The point I probe at center and outer is different because the inner material is different than outer.
However, how do I calculate the thermal resistance of Z direction?
Thanks for your help!!
ivanchi is offline   Reply With Quote
equivalent conductivity
calculation of thermal conductivity in reactingFoam sto16 OpenFOAM Running, Solving & CFD 11 April 25, 2017 00:46
Thermal conductivity issue Jared1986 CFX 3 March 20, 2014 11:38
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 18:26
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Warning 097- AB Siemens 6 November 15, 2004 05:41
